Taking air/fuel tuning to the next level, the Muzzy Digi-Tune uses the latest technology to provide one of the easiest and most accurate methods of tuning your fuel injected quad.
Every Muzzy Digi-Tune comes pre-programmed and optimized for each model. There is no mapping or re-mapping necessary. Adjustments for elevation and/or modifications can be done "on-the-fly" using three buttons on the faceplate.
WHY IT'S BETTER: The Digi-Tune is a load based fuel adder which works with the factory ECU. The Digi-Tune's simple push button interface and powerful load based technology renders complex table-based throttle position and RPM re-mapping systems a thing of the past.
LOAD BASED TUNING: The Digi-Tune ushers in the latest in tuning science – gone is the old throttle position and RPM (Alpha-N) based tuning, replaced by a powerful and highly effective LOAD BASED tuning methodology. Load based tuning is superior to old school systems because different gears place different loads on the engine. RPM and throttle position based systems cannot tell the difference between first or fifth gear. The Digi-Tune knows the difference and adds the proper amount of fuel for every gear, every situation.
2009 Kawasaki Teryx Digitune
Part #: 0015-00081
MSRP: $245.95
Muzzys
Website: http://www.muzzys.com
Phone: 541-385-0706
View the full article
    • By weasel
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
    • By NC4wd
      Has anyone installed the magnum tuning chip? Is it worth it? Noticeable difference? I have a 2021 Axis 500.
