Does anyone know if there is a interchangeable steering rack that would work from other brand of sxs
Are a rebuild kit to replace the bushing.
Mine is a 2015 Dominator 800 2×
The steering rack outer bushings are gone .
I didn't have to find new bushings anymore. We went riding a couple of weeks ago and pretty rough trail.Long story short it the already damaged rack and bracket ended up getting torn off and broken the rack.
I ended up getting a rack for a Polaris rzr off Amazon for $59.00 and a EPS for a Ace Polaris from Super ATV on sale for.$169.00  I adapted them to the Dominator going to finish up the work tomorrow night.
  • 4 weeks later...
Finally got it out on the trails a couple of weeks ago. The power steering worked great and the 30" tires, and the fox shocks it not like same machine. Very enjoyable to ride now. Very smooth.
A update it's worth every modifications I have done. I would do everything all over again.  It very smooth and climbs hills and going over Rock's and logs so much better.
      Any options on this machine
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Cletus
