Since the very successful race that Ricky Johnson hosted at the Perris Auto Speedway on November 8th there have been rumors of a series coming in 2009.  We have finally been able to confirm those rumors: There will be a 3 round Ricky Johnson Offroad Grand Prix.  All of the information that we have is [...]
View the full article
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Roadstar515
      Regards, Rick
    • By Kingfish
    • By shepdog
      I just picked up a 2009 bmx utv 500, there is a small 'nipple' on the water pump, its barbed like a hose goes on it , where is that little hose Suposed to go?
