Hisun 550 engine sputters, no power.
By Cory J
By Ductking1
By hisun junk
By JSwearer
Does anyone have any suggestions for aftermarket shocks. I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
