Register a new account
Sign in
    • By LarryLarryQuiteRepairy
      Hello,
      Background: Bought a used 2012 700, added 2 small LED lights, wiring for a sprayer and changed front CV axles.
      Had no electrical issues until recently. The old battery stopped charging so we got a new one, Rhino still wouldn't charge it.
      -Started next day, drove 15-20min, then out of nowhere the check engine light came on and temp too. 4WD started to automatically engage and disengage repeatedly. Charging display started jumping all around between 11 to 13 to 15v.
      -Relays, fuses, and battery connections seemed good.
      -Continuity on rectifier would jump btwn OL and 00.0
      -Rectifier wires from stator all read 20-21v at idle
      -Rectifier diode test had 1 bad reading. So, I replaced it with a new one (but still using original plugs)
      Started it up, still shows no change (12.1v idle, 12.8 with some RPM)
      Also, I feel like now I maybe also smell burning plastic?
      Does anyone have experience with this problem or have a recommendation of where to go next?
    • By Sisco
      Does any have a part number for the fuel pump sock for a 2016 challenger 700 efi. Does not show on any parts diagram but the old pump has one on it.
    • By Mnfish
      I have a 2016 Cub Cadet 750 Challenger Crew. My in tank fuel pump is inoperative. Can I put in an external inline electric fuel pump to replace the intank one? The inline ones are about $350. An inline electric one is about $25. Both are easy to replace just really expensive for the intank one. Any kind of inline external pump I should look at? What PSI is needed? Thanks for any help
    • By johnpeter
      2016 Polaris Ranger 570 4WD On Ebay
      https://www.ebay.com/itm/166657642388?
    • Get More For Your Device
    • By Felderlostnspace
      2016, Hisun 500 turns over great but Spark plug is firing when I turn the ignition key on. I’ve got good fuel pressure to the injector. Pulled plug out and it is wet with. gasoline. Air filter is clean. Turns over great just does not even try to pop or start.. I’ve checked off uses and they are good when I turn the key on I’m getting power to the injector.. I’m not hearing the injector pulsing, but may just be my hearing.. With the spark plug getting wet with gas I feel like the injector is pulsing and spraying. Any suggestions would be great. I don’t know the hours on the unit offhand, but it has 600 miles on it. Thank you for your comments and advanced.
