Season Greetings
By Paul Angstadt
Paul
By diamondjfarm
Thanks.
By mcraigchr
I realize that many of you do not have diesel machines. For those that do, this is for you:
Just wanted to post my experience this past week. Here in Texas, we had pretty good dip in temps. For 4 days it did not get above 25. At night, it was single digits or close to it. I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon). And up until this tank I was using Power Service (white bottle) for anti-gel. Never had an issue.
This tank, however, I switched to Stabil All season (anti gel). It is supposed to good down to -40. Zap. That is a big fat lie. I put in twice the amount called for in the instructions. Result was less than optimal. I drove the SxS 100 feet (to go get the mail) and it died. I looked at the fuel bowl and it was a cloudy, wax substance. So, the Stabil did not work. That said, I'm not sure that I ever tested the Power Service in the same manner. So I am not saying that one is better than the other.
What are your experiences? Are these products inferior? What do you folks in the northern states / Canada use? Am I missing something?
CC
By Hisun .500
So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
By Kevin M
Hello all. I am new to this forum and new to SxS in general. I recently purchased an 16 Odes Dom 800 with the issue of a prominent knocking noise at idle and it’s very jerky in forward and reverse gears. It does not sound like an engine knock. I bought it cheap knowing about this problem with hopes of it being a cheap and fairly easy fix that I can do myself. Would a bad belt be the cause this symptom? I’m looking for a starting point to begin diagnosing and fixing the problem. I recorded a video of it but am not sure if I can post it on the forum. Any help is greatly appreciated.
