I purchased a Gator 625I recently and after owning it for awhile realized  the top speed was limited to approximately 25 MPH. I talked with my local JD dealer and they told me this was done on this model for emissions reasons. I didn’t buy this for a racer but would like a top speed of around 40 MPH. Is there anything fairly simple that could remedy this? Thanks
Probably no cheap way. at 25mph you're probably at the max of 3600 to 3800 RPM of the engine.
I also read across several different forums and their seems to be no way around it. Unless you know a racing engine and transmission mechanic.
    • By SteveS
    • By rdborra
    • By Chucky 1
    • By Jerrys500
      Thanks Jerr
    • By TPlummer
