my friend has a 2018 Massimo Warrior 700.  It will continue to run, even after removing the key from the ignition switch. And stays running until he disconnects the battery.  The other clue is the left head light stays on, he has burned out three left headlight bulbs in a year.  He has checked for loose connections.  One final clue is he went through a 6 inch puddle of water, so some wires may have gotten wet.  It’s been inside for 4 days, with same symptoms.  Any ideas?
thanks in advance
    • By ToughLuck
    • By Gorj
    • By Joe Breaux
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By SteveS
