On 10/6/2020 at 1:14 PM, miten000 said:
Thanks man!! I really appreciate it!!
I recommend the Ultimax UXP446 for all my clutch kits and dimension wise it is the same as the XTX2236 or 30C3750.
If you have the 800 you will need to re-shim the secondary as even in oem form they are a little slack on belt deflection.
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By Paul Angstadt
      Paul
