What do you do when
Go to solution Solved by Travis,
  On 11/19/2020 at 12:47 AM, T-boss 410 said:
I would be very interested in finding out what the cost of the gear was for the dealership, and then compare that to the retail cost. I bet we would be amazed!
Expand
In my experience with repairs to my vehicles, dealerships and repair shops charge 2x-3x the retial price for parts that I can buy at NAPA's retail price.  My AC compressor $995 from the dealership, $485 fromn NAPA.  I don't buy lifetime warranty parts.  They are exactly the same  as the 90-day warranty parts, just painted a different color.  You're paying about 50% higher price that their lifetime part and they're betting you won't need to replace it.  I've never would have been able to collect on a warranty replacement on anything I've ever purchased.
and people say I'm too hard on Chinese manufacturing?   I also suggest you take your original to your local Automotive Electrical repair shop. Let them rebuild THAT one .. My local shop rebuilt a starter for $59 that Ford wanted $425 for new . Its been working for 6 years now
If you have the Kawasaki Mule with an 800cc gas engine, then even though Kawasaki is a Japanese brand, that engine is a Chery engine from China.  Trouble is, most of my parts I have to eventually get from China.  Few parts are available in the US.  I've found some parts I needed for my ride on Amazon.com..  If you go there, be sure to check the sellers ratings.  One seller for Kawasaki parts had a 69% favorable vs 31% unfavorale (I look for 95% or better favorable).  You might find the starter you need for about $60.
CLICK CLICK CLICK CLICK CLICK CLICK.
I'm going to buy a new Arrowhead starter for $80 from a small engine repair shop,... I'm not taking that starter off one more time only to not have what i do work. im sick of it, i've  had that starter off 8 times in 2 weeks. i have busted knuckles to prove it. On the plus side i am now an expert on starter removal and can have it off 2 minutes, LOL!
there's got to be something not aligned right with that starter, because just a few taps with the the hammer and it starts right up.
I'm sorry to hear that. Could it be somehow binding up when you tighten it down? Maybe the body of the starter is somehow bending a small amount when you torque it down, and tapping it with a hammer loosens it enough to crank over? You said it spins fine when you tested it off the machine, correct?
Expand
yep, spun fine not bolted up.   I think this arrowhead starter ought to do pretty good from Jacks.  I was told by a friend who is a Briggs dealer that they manufacture alot of the starters and switches etc. for Briggs and  Kohler.
Expand
Expand
Have you checked the battery with a battery load tester, My Craftsman riding mower starter went CLICK,Click,Qruick, Qurick and after pulling al  the covers etc,etc, then checking how much a starter costs, load tested the battery and it had a bad cell, new battery fixed everything
Expand
Not with a load tester, but i have checked the voltage drop when it does click, it only drops to 11.9 volts. Which is what i get on a good battery in my rider mower when i tested it, And when it does start, it spins over easily.
The battery is new from the dealer as of March this year.
Does it ever turn the engine over at all ?
If not pull the sparkplug out to relieve the compression and try the starter, I bet it may be the battery, cable or solinoid .
Hey, I am over 80 years old been working on cars and trucks ever since I was a pup.   I rebuilt the engine on my 1930 Ford model A when I was 12, and I still got stymied with a 12 volt battery with some bad cells. and a leaking carb float valve that filled my single cylinder engine's cylinder with gasoline (guess what....gasoline don't compress)  while it was parked for a month.   I  have been learning new stuff forever.  I am not a big fan of Japanese and Chinese 4 cycle  Internal Combustion engine designs. 😒
  On 12/11/2020 at 2:47 AM, T-boss 410 said:
Sorry, didn't know that. I guess if you want a name brand, you'll be paying for it. I hope it's not too expensive.
Expand
It's made by Arrowhead, $80.00, they're not top of the line  (Like Denso) but it's better than Wee Fewl Yu from china.
  On 12/11/2020 at 3:00 AM, T-boss 410 said:
Is this a rebuilt unit, or new? Seems I remember them making starters for mowers.
Expand
Brand new,
yes, according to a friend who is a Briggs tech, they make some starters and other electrical components for Briggs and Kohler, and also for the aftermarket seller Stens.
    • By Grant
    • By rsar
    • By TjB
    • By Will D
    • By rsar
