Trooper Easy to use Shock adjusters
When I'm out at the trails, I like to be able to adjust my shock preload based on what I'm going to do. If My wife rides, I want it soft as she has a back that bothers her. Then, when I hit the trails with the guys, I want to firm it up. This was too much of a hassel with the stock adjusters so I didn't change it. To correct the problem, I removed the stock adjusters and made new ones. I used radial roller thrust bearings with an O-ring seal. I now can change the preload without releiving the spring pressure and I can do it without tools. I do have a viair air compressor on my trooper with a 3 gal. tank that I can load to 200psi. With this high npressure, I can blow the shock threads clean before doing any adjusting. The 200psi and 3 gal tank also allow me a better chance to seat a stubbern bead seat. My jack has an attachment which will break a tires bead for internal tire repairs.
I've included a pic of my shock adjuster mod.
Nice piece, i like the o-ring to keep the grit out, could the bearing be recess into the nut.
Thank you. The bearing is recessed into the lower sleeve. When assembled the space between the two peices is .010". "The O-ring closes up the .010" gap. If your refering to recessing the bearing into the threaded part, yes I could but to help keep turning forces spread, I wanted a good long adjusting nut. This helps the lubercant to keep the two threads apart otherwise the heavy forces may press through the lubercant. I even use a synthetic oil for better film strength. The big problem with the stock adjusters is that they are too short and suseptable to gulling which they do pretty easily.
How much do you think you would charge for a set of 4 of those adjusters?
Jeff
Another idea would be to drill and thread a hole in the side, drop in a piece of plastic followed by a set screw or winged bolt to lock the adjuster in place, unless you think it will stay put.
Jeff
I'll take a look and see what I can get the aluminum and bearings for. If I'm making them for other people, maybe my bearing supplier will give me a break. Also, if I can get the aluminum cut to needed lengths, this will save machine time and material. My supplier uses a circular carbide saw to make the cuts and thus they are cut quite square and require just a little cleanup on the lathe. If I cut them, I would use either my horizontal or vertical bandsaw . Unless the blade is almost in perfect condition and adjusted perfectly square, going thru a 4" dia. round could get off easily as much as 1/8". This would be on both ends so you can see the material and machining difference. I have always had full control of all parts of a project but in this case, I'm machining threads for something that is elsewhere and thus I can't be totally confident of proper thread match. It would go on but it could be a little too tight or too loose. As a result I would prefer I had your shocks here. then when I machine the threads, I begin test fitting the two peices together when I'm nearing the proper thread depth.
I don't feel the adjusters will move on you. Mine haven't shown any inclination to move even the slightest bit.They still turn stiff because of the spring pressure. Not so much at the beginning of spring compression but when it starts loading it's a firm grip turning them. The ones you see in the picture is the rear shock. I'm restricted on length of the turning handles but I still do it by hand myself without an extension bar but I plan on putting 4 turning handles on them next time. That way my wife can adjust them by using a short 7" long pipe extension and moving from one handle to the next. At 7" out, it requires about 30 pounds pressure to turn the adjusters Thats pulling on one adjuster at a time. The front shocks not only have a lighter spring but room for much longer handles.
Forgive me for getting wordy but I like to lay everything out for people plus I'm sorta a wordy guy anyway. Let me do some checking and I'll get back to you with a quote. It is maching job and it takes a while so it's not real cheap but maybe it won't be so bad either. If I could make 3 or 4 sets at a time saving multiple setups, I could cut my machine time down.
Very nice. How about a set of wheel adapts, big pattern VW to our pattern? I would like two so I can run paddles in the rear with VW rims.
rocmoc n Mexico/AZ
Thanks, I'll take a look at it. There are 3 diff blot patterns they use. I assume you want the 4x100? Also do you want to add width or keep them as thin as possible for structural requirments? Let me know and give me a little time and I'll get back to you.
Rocmoc has a trooper and troopers run a 4/115 bolt pattern on their wheels
Kinarfi is correct. Width is not my concern, strength & safety is.
rocmoc n Mexico/AZ
I know that the trooper is 4x115. I'm asking about the bolt pattern on the VW wheel, I beleive what you want for that is 4x100.
Is this correct?
    • By bfisherman11
      In 2016 I bought a midsized Ranger ETX. I don't recall exactly my out the door price but it was probably less than 8k. I've used it as a work machine around our home and 38acres. It's always run great and requires little maintenance. Still running strong.
      So, for no reason I checked out a local dealer. I like the midsized UTVs so that's where I started. I was shocked the cheapest 570 I saw was a shade under 18k. I know an ETX Ranger was a budget SxS but wow, that's a 10k jump. When I was shopping back in '16 I think a 570 was about 1k more than my ETX.
      Well I guess I will be running this ETX till it breaks.
      Anyhow, I'm a big fan of the Rangers. When the time comes I'll be back but I had no idea. I haven't posted in a while. The ETX must not have sold a lot because you don't see many things posted. Hope other ETX owners had the same reliability I have had. I'm guessing if a cheap Ranger series like mine has been reliable then the guys with bigger ones are enjoying those as well.
      So, great machines, probably priced per the market but I had no idea. Ha
    • By mark walkom
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Woody77
      UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
