I have an issue with my odes. It will start up and run but when you give it gas it stumbles and cuts off. I have replaced the fuel pump,fuel filter, fuel injectors, mass air flow sensor,idle air control,throttle position sensor,air filter,spark plugs,and throttle body also I have no vacuum leaks either. I have even replaced the ECU. Does anyone have any idea about what could be wrong? Engine only has 1045 miles on it
  • 7 months later...
After my repair center tried for 7 months to fix, I finally found that the hose clamps on the fuel filter were allowing air to get into the fuel line. Replaced the hose clamps with better ones and cured issue
  • 2 months later...
    • By Aaron Colona
    • By Mike Jenkins
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
