Hello all -
I am in need of some help. My 2021 buck 60v is not charging. I have no owners manual or service manual. I can’t even find it online to purchase. (Does anyone have one they can share?)  I am having electrical issues, it’s not appearing to charge even after being plugged in for over 12 hrs. Any ideas?  Thanks.
  • 5 months later...
Same problem here also took on board charger in to get tested and it's fried so now trying to find a place that sells these things to buy new charger... noone up here in north dakota sells these electric utv.. curious did u buy from a dealer.. if so where they located.. thank u
Rich -
We ended up going straight to Massimo to order the part which was a fried charging board (the inside of the box was all charred with melted wires). Call their 1-800 number and if its still under warranty like ours was, you may be in luck, otherwise its not a cheap part to replace. The parts do ship quick and was easy to install. Hope this helps.
    • By Dennis
    • By Marie
    • By Grant
    • By SteveS
