Replacing 2017 Honda pioneer 1000-5 utv rims with after market rims.
On 10/29/2020 at 3:37 PM, Carl Rhodes said:
2017 Honda pioneer with front tires 27-9R12 (rims 6.5 wide) and back tires 27-11R-12 (rims 8.0 wide).  What issues if mounting theses tires on rims 7 wide?
That's a huge sidewall. I'd think that they're very forgiving as far as wheel width difference. And it's such a small difference, that my guess, is that there's no problem. The rim manufacturer would know the absolute answer. Because of safety reasons, they'd almost have to respond to your inquiry.
    • By Bbicon
    • By Dennis
    • By Joe Breaux
    • By John Doe
      Hello,
