Replacing 2017 Honda pioneer 1000-5 utv rims with after market rims.
  On 10/29/2020 at 8:37 PM, Carl Rhodes said:
2017 Honda pioneer with front tires 27-9R12 (rims 6.5 wide) and back tires 27-11R-12 (rims 8.0 wide).  What issues if mounting theses tires on rims 7 wide?
Expand
That's a huge sidewall. I'd think that they're very forgiving as far as wheel width difference. And it's such a small difference, that my guess, is that there's no problem. The rim manufacturer would know the absolute answer. Because of safety reasons, they'd almost have to respond to your inquiry.
    • By Dennis
    • By Joe Breaux
    • By John Doe
      Hello,
      I have a T-Boss 410. When I shift to H it starts beeping like it’s in R. It also shows R on the instrument panel. Fixes?
    • By bms stallion owner
    • By Bryan g
      We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There  is a bulletin Im sure everyone has saw about adjusting shift cable.  That dont always fix it.  I went round n round with coleman  on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair "   I told them shift lever does not have enough travel .  No amount of cable adjustment  will increase travel . I  extended lever with piece on flat  iron by 3/4 of inch .  This gave shifter enough travel to properly engage into gear completely .  Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out,  grease  all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts,  brake hose  routing , make sure not touching exhaust .  These are just  few of the more common failures I see .
