I have a 2012 Coleman (hisun) hs700. The cooling fan quit working. I replaced the water temp sensor/ radiator fan switch located towards the bottom of the radiator. That did not cure the problem. I also put 12v directly to the fan to make sure the fan was still good. I then took the harness off the new temp sensor and shorted it to turn on the fan and nothing. Is there something else in line I should look at? I also found the sensor at the motor and jumpered through it. Still did not work.
Any suggestions?
I am assuming that you had the key on when you jumped the thermoswitch plug. On my Massimo there is a fuse/relay box under the hood. Not sure where it would be located on your machine, but there is where you will find the fuse and/or the relay for the fan.
Did the fan run when supplied with direct voltage?
T-Boss
Thanks for replying. Yes I did have the key switch on when I jumped the thermostat. And the fan did run when I applied 12v. I also have a fuse box under the hood and tested all of them.
  • Alex changed the title to 2012 Coleman HS700 (hisun) fan issues
Have you fixed your problem yet? I'm having the same (or similar) issue with a 2012 Bennche Bighorn 700 (Hisun 700).  Cooling fan works when voltage is directly applied. Temp switch works fine, and when jumpered there is voltage to the cooling fan plug.  As soon as I plug in the fan, the voltage is GONE.  I'd love to find a wiring diagram.
    • By CapnWalleye
      I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution.  Today I removed the O2 sensor and it is black on the end.  To me that means it's running rich and/or the sensor isn't working.  I replaced the sensor with a new one and will see how it goes I guess.  With EFI, I'm wondering why the sensor would be this way with low hours and mileage?  Is there a way to adjust or lean out fueling on these?  Thanks in advance.
    • By Marie
    • By Marie
