    • By Nikonianut
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
    • By BernieG
      I could really use some help identifying some disconnected components on a Yard Sport YS400. The first part is this pipe, which comes out of the exhaust port area or the cylinder. It looks like it had a piece of rubber hose on it, but the hose is gone, and I have no idea what it was previously connected to.
      The second item is this vacuum valve looking thing.  Again only one line is still attached.  What is it's function and what other lines should be connected to it?
      The last thing is this hose, which exits the side top of the fuel tank (not the fuel line hose) but is not connected to anything
      Any help the community could provide would be greatly appreciated.  This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
    • By lozomex
      After a few days of heavy rainfall I got in my Sidekick and noticed that the belt seemed to be slipping as I was making my way out on a large property.  I turned around and could barely make it back to my shop.  After removing the cowelling I noticed about a quart of water drained out.  I dried the area, the cover and checked the belt.  No signs of dammage, belt looks great and no foreign debris other than water in the area.  I put it back together and there was a definite improvement.  The Sidekick is driveable now but the belt still slips but only at a higher speed and only when the throttle is punched.  I'm wondering whether I may have inadvertently damaged it while it was wet and have ordered a new belt.  I have looked on line to see if there is a guide or procedure, specifically for the CVT belt removal and replacement for the 850 but can find none.  Does anyone have experience with this?
