First, understand that my T-boss 410 doesn't move very often, since I don't yet have a trailer and no trails nearby. So I occasionally go out and start it, let it idle, and take a ride around my property. This time, the battery was all but dead, so I put it on a charger. It showed a full charge after a few hours, so I reinstalled it in the UTV, and attempted to start it again. It acted as though it was almost dead, as before. I hooked up the charger and jump started it, which took several tries. It's the stock battery, but the unit only has 14.5 hours on it. I purchased it in an auction on Ebay back in December of last year. It was a floor model. Everything seems in good working order. Could I have a bad cell in the battery? How can I test for that?
Do you have a multimeter? if so
Set it DC 20 volts, attach the leads to  + and -, take note of the voltage, turn the key to START, take note of the voltage, if it drops below about 10.5 volts, 99% of the time bad battery. Auto parts stores like O'rielly's will load test batteries for FREE.
Thanks, I will try that. I am aware of the auto parts stores testing a battery for free, I am just trying to avoid going out as much as possible. The COVID 19 infection here is really high currently. I also feel sort of beholding to the parts store to purchase a new battery there.
This battery is a 335CCA unit. I would think it would spin the motor easily.
I was thinking the same thing. I'm trying to research a way to rejuvenate the cell, or if I can't do that, then renew the battery. I see plenty of ways on the internet, but some seem so outrageous that I just stopped searching, at least for the time being.
Would a battery for a lawn tractor work? They seem to be much more affordable than one specific to powersports.
Expand
as long as you get the correct CCA i don't see why not.
Expand
I ordered a battery of the right size and amps from Amazon. It is more likely you have a battery with a bad cell, one of these gave me a problem for two days, it caused me to tear down the body to get to the starter because my new tech battery charger gave a full battery reading but the starter acted like it was dragging. I had checked the battery for voltage with a multimeter, but finally hooked it up to a battery tester (One that can add a heavy load).  It showed under load only 6 volts. A new battery fixed the problem.
A Harbor Freight battery tester probably costs less than a 40 mile trip to WallyWorld (that is how far I am from a big town with a wallyWorld or a McDonalds.  Out here in the Boonies the RFD mail carrier delivers what Fedex or UPS don't. Then you don't have to wonder about that battery.
I have this one from Amazon
Battery Load Tester and Voltmeter"> Schumacher BT-100 100A Battery Load Tester and Voltmeter
Well, hooked up a load tester. It showed 12 volts before the load was applied. Once I applied the load, the needle fell almost as fast as it would if I was disconnecting the tester. Fell like a rock! Guess I'm in need of a new battery!
    • By Gorj
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
