I just bought a 2019 Odes Ravager 1000.  I took it in for a check up at my local offroad shop.  They changed oil and oil filter.  There's a leak around the end cap.  Has anyone had this same problem?
  • Alex changed the title to 2019 Odes Ravager 1000 oil leak
The endcap looks good. It has a female groove for the "o" ring to seat in.  I have a feeling that the previous owner had the problem and took it someplace for repair.  It had some kind of silicone sealant on it.  The guys at the shop tried different "O" rings and a different oil filter.  The last try was with an OEM filter that included the "O" ring.  I'm wondering if the bolts on the endcap should be torqued.
Thanks for ypur response.
Oh, does this use a filter  like these? AHL 123 Oil Filter Grid For ATV kawasaki Bayou 250 300 220 ...
Where you actually put it "in" the engine, and put the cap on over the end?
Most likely those  screws do need torqued, but usually both of them being snug should be adequate, might call or email Ode's and get a torque spec.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Texjpr
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By mark walkom
