I have been looking for a cab enclosure for my 3010. I accidently came across one for a 4010 on Amazon for $27. 00. I could not find out if it fit or not but for 27 bucks I figured I would try it. It fit better than I thought it would. If you don't have a windshield, you will have a good gap at the bottom. But with a wind shield it works great. Enough that I ordered a second one  for later.
Just figured I would let people know.
IMG_0007.thumb.jpg.8328353498c1f73c54a0581edca25b4d.jpgIMG_0008.thumb.jpg.02d9a5e9fe503df26117c1cd2cd9cab6.jpgIMG_0009.thumb.jpg.ed595b8a07fc9730e0197f36fbcb84ae.jpg
  • 4 weeks later...
Sorry for not getting back. but the doors zip in or out. They fit well. It is made better than I thought it would be.
    • By Jacob E freeman
    • By Kingfish
    • By mac66
    • By sxr951
