So I was reading there is only two safety switches. The brake switch and the neutral safety switch. Is that correct? Is it the park brake switch or the foot brake switch? The brake lights work and neutral lights up on the dash so I am assuming that they are working.  Anything I need to know?
thanks Travis
  • 4 years later...
I am having a starting issue on a Hisun Strike 250.  As far as i can tell everything is working,  The Solenoid will start the engine when one of the trigger wires is connected to ground.  Brake switch seems to to work the brake lights come on, the Parking brake warning indicator comes on when applied and Neutral is indicated in the instrument panel.  Both trigger wires are constant hot,
    • By BigWave
      Bigwave
    • By Mike Jenkins
    • By HighSon
