2020 Massimo Buck 400 Snow Plow
I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution. Today I removed the O2 sensor and it is black on the end. To me that means it's running rich and/or the sensor isn't working. I replaced the sensor with a new one and will see how it goes I guess. With EFI, I'm wondering why the sensor would be this way with low hours and mileage? Is there a way to adjust or lean out fueling on these? Thanks in advance.
By Joe Breaux
By Alien10
Has anyone purchased a snow blade that can offer the make and model they bought and any comments, pros cons etc.?
Thanks in advance.
By SteveS
By Adrian Domingues
Thanks for your help
