How to find the Best BBQ in the south..
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By Greg Kilgore
I did compression test.
How hard is it to replace?
Advise?
By sxr951
By Sma
Got a 2018 textron , looks like the head gasket is blown , been doing research and can't seem to find any (out of stock) or back ordered .
is it possible that I have to change the complete engine ??
can someone help me out Cheers
By Don W
Changing head and head base gasket, rear cyl. Can anyone help with head bolt torque? Thanks!
