Posted (edited)
Hi, I think I just bought a Husun 450 that is in need of TLC. It is leaking badly from the shifter shaft (located at left foot). I can not find a part number for the seal(s) 3 came off of the shaft.
If anyone can help I would be extremely grateful 🙏
Edited by Russshaw
Added to title
6 hours ago, Veggykiller said:
I know everything about this bike. Email me
Why not continue the conversation here to benefit others with similar questions?
Email address removed to prevent scraping.
I was trying to send messages here yesterday but it wouldn’t let me.    If anyone is trying to buy anything fir the Subaru 450 Atv motors please buy any related engine or transmission parts for a Polaris predator 500.   It is the exact same engine. I have done it my self. I made my Subaru 450 into a 500  by switching cylinder jug and piston.
    • By Marie
    • By Grant
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By camojay
