New Billet Spare Tire Carrier from MachineTrix
By SpaceGhost
By redneckred
I have a 2012 Bennche Bighorn 700X. I bought it used. It had been sitting in a field for several years untouched. I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel). The machine cranked and ran beautifully. I had it over a year and then the machine quit running. As it would not stay cranked, I narrowed the problem down to a bad IAC valve. I replaced it and it ran as good as new/old. Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear. Then forward quit. I assumed a bad CVT belt and got one. Started removing the bolts from the cover and (3) just turn in the housing without coming loose. (2) are on the bottom, so very little room to do anything with them. I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank. It turns over fine. It gets gas to the injector and has spark. I can spray cleaner down her throat and she would run until it ran out. I have replaced the IAC twice and put a new injector with no change. I went out and put the old injector back in to see if that made any difference and, well, it did. I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off. I have to disconnect the battery to stop it. Before I shoot this thing, what am I missing? Is this an ECM problem or something else I am not seeing? Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving. I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful. Thanks in advance.
By REDfletching
Spent today at a Honda dealership looking at their 520 side by side, then on the way home past our Lowes noticed they had several new UTVs on site, so we U-turned and ducked in there. We were impressed that all that came for $9,999 metal whole length skid plate, nice sized bed, roof, windshield, side mirrors, winch, upgrade looking tires… all of which would have added thousands of dollars to an already expensive Honda 520. Now Honda does have a great reputation from my trusted UTV experienced buddy, so it has that going for it.
