    • By Poppateets
    • By Frank in MI
      Thanks for accepting me!
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
