I just bought a 2019  MSU 400 w/ 700 miles.  I got it home yesterday and noticed a faint rubber burning smell.  I can't track it down.  I'm on dirt so its not tires and pavement.  Parking brake is off.  Temp on the machine appears fine.  Thx for any suggestions   I thought maybe belt but I'm not racing nor going but a mile or two.
  • Alex changed the title to 2019 Massimo MSU 400 Burn rubber smell
i would start it up, or turn the key ON, and feel of any hot wires you can reach, such as the main + battery cable, to be sure there isn't a short burning the coating off a wire.
also check for any thing that may have fell on the muffler/exhaust pipe.
    • By SteveS
      Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time.  Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters?  Almost acts like it might be clogged if so.
    • By judy140
      I am looking for a service manual for Bighorn Explorer 400
