I have a Massimo Buck 400. I want to change the engine oil.
I know this is a "duh" question, but to do that I need to take the heavy plastic cover off that is mounted under the frame. Then find the drain plug which I assume is in the front of the vehicle. Did I get this right or can you guide me further?? 🤠
Many thanks.
Mitch
Look for a round hole about  1 and a half in.  Toward the center of the skid plate.  The drain plug should be accessed there.  Should not have to remove the plate.
Thanks, Verno. Prior to your post, I had looked under there, but apparently did not see these openings. I do now.  This will save me much time, skinned knuckles and bad language.
Be safe.
Mitch
Quote
I'm looking for the filler tube or where ever I fill the engine wit new oil. I down loaded the service manual but it never shows where to add the new oil.  Help please....
Mine looks nothing like the illustration you sent.  Mine is a 391cc engine in a Massimo  Buck 400.
So  I believe the dip stick to check engine oil is the yellow one. Below it maybe 5 inches is a small plastic dip stick.  It comes out and is maybe 3 to 3.5 inches long. If the engine oil is shared by the transmission? Maybe this is where to fill the oil. It seems to be to low for the engine oil?
I have attached a photo  I took today.
Thanks for your help.
Still looking for help changing the oil on my Buck 400. It looks like maybe I have to remove the shifting cable and the remove the  dip stick? surely it is easier than that.
This is a 2019 model. I have around 150 miles on it.
OK I called Massimo Tech service.  It is as I thought but I don't like it.  There is a hex nut at the bottom of the dipstick. You have to remove the entire dipstick to fill wit oil.
Not a smart setup. It takes about 1.4 QT. of 10W30.
Just a thought.  You should have a crankcase vent for the pressure to escape buy it may take more pressure to open.   You're welcome.
I have bought 2 different wrenches for oil filter on my 2014 mule, and still cant find one the does not slip on the oem filter.  What do you use?
Channel locks or a chain wrench
@Verno At wouldn't say at its best.LOL.
2 5/16-24 screws, i ground a taper on the end of. And a 7/8" nut on the end.
Changing my oil filter has never been easier or quicker,and saves my knuckles.
Another option would be to buy a KN filter with the 17mm nut on the filter.
The "hex nut" is just an adapter for the "push-pull" dipstick--many motocycles, etc. have a screw-in dipstick as shown in the illustration Travis provided, Removing what you have is no big deal--however 'twas me, I'd get rid of it and get a screw-in dipstick that can be removed without tools--just  for convenience' sake.
My Coleman (Hisun) Outfitter 400 has the more typical screw-in dipstick. I made an extended  screw-in adapter (3D printed)--it's just a 3/4-10 thread:
To which I can connect a 1/2" ID hose and funnel when refilling the engine oil:
9 hours ago, KentC said:
Sounds like you could have a small EBay business selling the new dipstick.
I'm printing a half-dozen of them now (takes 7-1/2 hours) the resin costs  about $1 each, nothing else but wait, cleaning and final curing time; a 2¢ O-ring, and a tiny bit of electricity--if anyone is interested in one give me a yell--we'll work something out (an SASE or whatever)...
Here they are at the end of the print cycle (the SLA resin printer "prints" things upside down, the supports [hangers] are needed for dimensional stability:
Ready to be popped off the build plate:
In the "oven" for the final curing:
The "oven is a gutted 0.7 ft³ microwave oven, with nothing left but the turntable and timer. The Magnetron was replaced with a 30 W 405 nm UV LED array. 45 minutes of that fully cures the resin...
The postal service will not let them be shipped in a plain ol' evelope (too thick)--I'll figure out the most economical shipping method and  post a message in the Classified section....
Spent some time this am looking at shipping options--and find none that make any sense. USPS Priority Mail small flat rate box is $8.00--Parcel Post is $3.30-$4.00 (and I have to  provide packaging). This makes it senseless for me to try to sell them.
So, if anyone finds themselves in the Saint Augustine area give me a yell and I'll give you one...
This is what you have. To do an oil change without trying to pull the drain plug and it's attached oil screen,   pull the dipstick and use a short handle 7/8" open end wrench to unscrew the dipstick bushing from the aluminum engine sump casting, yes the shifting cable is in the way, be careful not to break the shifting cable housing.  I used an oil change suction pump (12 volt) to suck out the used oil, added a half Qt of new oil to mix with the residual old oil in the sump and then use the suction pump to suck out the half Qt of new oil and the residual old oi,.  Since you will only need a Quart and half to fill the sump. You will need the remaining qt. and 1/2 of oil.
 I used an old automatic transmission oil funnel to fill the sump with new oil. Screw the dipstick bushing back in the engine and check the oil level with the dipstick back and be ready to go.
I have a Liqui-Vac  "suck-o-matic"¹  2000 2 gallon hand pump vacuum unit I use on our small engines when I get lazy:
I used it on my Outfitter 400 at the first change and got out a tiny bit more than 2 qts.; per factory specs the 400 holds 2.2 with the filter so I got most of it from it from the crankcase and did not have to crawl under it.
Though it goes against my basic nature I may use it again at the next change. If I get 2 qts. again I'll b e a happy camper...
¹ - I really shouldn't call it that as it works quite well--I've had it for well over 10 years. It's like a vacuum cleaner--they more they suck the better they are.
My Buck 400  holds 1.4 Qts.  and I figure it was prudent to use the other half Qt to mix with the small residual anount the vacuum would not pick up. since I buy 2 Qts for an oil change, I didn't want to contaminate the sump  with other oil than what should be put into the engine, , I figure on the third oil change I wil go under and pull the drain plug and clean the screen.
    • By KimAC
      -Kim
    • By shawn b
    • By Reynolds Rocket
