By Jon Spruill
By Pick a name
The Axis 500 will not shift into low or reverse. I have high when it should be in low and all the other places it is reverse. The gears in the shift cover are fine and I shifted it when the cover was off and yet no change (so it can't be the shifting mechanism gears). I t has been difficult to get it into low for awhile. But now it is either high or reverse, no neutral either.
By Gorj
