Stock rear shock mods
By Flanman55
2007 Hisun HS700 will not crank. Replace the ignition switch. Same thing. Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
By SpaceGhost
By Croppy38
I own a 2017 Challenger 750 and had the key way snap at the flywheel. It was removed and cleaned up and then the flywheel was put back on with a new keyway. It snapped a second time so the flywheel and keyway both were replaced. They both seem to fit nice and tight. Put it all back together and it snapped again. I have no idea why it is doing this.
By camojay
