Purchased it used a week ago.  Found that it wont start from key but will start if solenoid jumped. Also noticed that brake lights don't work checked switch and its working, may be the no start problem from key.
Turn signals and hazards do not work headlights tail lights and hi beams all work.
have a manual but it is hard to decipher.
Hoping that someone has run into these issues and can point me in the right direction with the lights. I believe if i can get brake lights to work it may solve starting from key issue.
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By Rick A
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By BMurph
