Hi Kyle!
what brand and model UTV do you have?
usually a three prong puller will do, i thread the retaining bolt in with about 1/2" to 3/4" from the head of the bolt to the clutch, and put the stud of the tool on that bolt head, slowly tighten it, give the pulley an occasional tap with the hammer to help vibrate any rust loose or corrosion.
Looked up the parts diagrams, that pulley looks very similar to the one on my mule, i just used a 3 prong puller on it.
PULLER MEDIUM 2 OR 3 PRONG Rentals Oak Grove MO, Where to ...
now when you go to put the pulley back on, put some never seize or some kind of rust inhibitor on the crankshaft, it'll came off easily if you have to remove it again.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By FDWT9956
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
