By FTG-05
Â
By SpaceGhost
Â
Just picked up my first side by side a couple days ago. A 2020 Can-Am Defender HD10 DPS 6x6.Â
Â
It's in pretty good shape, but as you can probably tell, it's sitting a bit high. Former owner put a lifting collar on the shocks.Â
Â
The good = almost 17" of ground clearance. (30" tires)Â
The bad = incredibly steep driveline angles, and a pretty stiff ride.Â
Â
They will be coming off.Â
Â
Other than that... clean as a pin and appears very well maintained.Â
Â
Looking forward to seeing what this forum can bring, and hoping I can bring something in return.Â
By CRV
I’m need a couple parts. Diff. Lock Actuator mainly. But I would like to find a donor that maybe has bad motor or something along those lines.Â
if anyone has or knows of anything please holler at meÂ
thanks RandyÂ
By Prepper
Hello All...
    Just bought a 2014 Massimo 500 UTV. It;s not running at the moment, but hopefully will soon. I need a seat for it also (passenger side, if it makes any difference.) It is a crank-but no start situation. Just now starting to read the boards for solutions. Apparently these models are well known for this issue. If anyone has any suggestions, please feel free to chime in, it would be greatly appreciated.
ThanksÂ
By SayHiToRambo
08 trooper 1100
Bit of background. First the machine would take for ever to start. So I adjusted the valve shims into spec and made sure the timing is correct. Starts perfectly now.Â
Â
now it fluctuates on idle. Bogs down, Revs up, repeat. I noticed the fuel pressure drops from 60psi to 20psi while that happens. It also bogs down at the lower end of each gear, higher rpm seems to be fine. Seems to struggle under load. In neutral it revs up perfectly.Â
Â
brand new fuel pump, fuel filter, gas. I noticed on the fuel pressure regulator there’s that vacuum nipple, it’s not attached to anything and I’m not sure where it would go. Possibly the problem?Â
Â
Another issue is the tip off the end of the exhaust is broken off, sensor is still attached and connected. Could that cause these issues?Â
Â
my next plan was to look into the pressure regulator and voltage to fuel pump while driving. Is there anything I’m missing or any ideas you guys have?Â
Â
thanks!Â
