Hello all,
While "surfing" at Amazon I stumbled across this Wireless Winch Remote Control for $17.
It comes with absolutely NO documentation, but fortunately I was able to garner what I needed from scouring the web and examining the wired pendant controller that came with the "Thing" (what SWMBO calls my Outfitter 400).
Once installed I found it performed just as claimed and in fact better--my testing found the remotes to have  a solid 120 + ft range--though I cannot for the life of me envision a situation where I'd want to run the winch from 100 feet away?  The control module is fully potted and waterproof, the remotes are well made and as sturdy as they need to be,  HIGHLY recommended!
If anyone is interested I can post photos and a wiring diagram...
  • 1 year later...
I am interested. I accidentally broke my winch joy stick thing and i taped it up and it worked for several months but now it is completely defunct and i don't have the knowhow to splice the wires any better. This is for the same utv you have.
I don't think cliffyk posts here anymore due to gthing rid of his HS400 after some medical issues.
I don't see that particular remote available, but looking on amazon there are tons of other similar ones available in the $20 range.
Hooking it up you will need to be able to splice some wires or crimp some terminals.
The winch control relay is under the front hood towards the top middle. It's a little square box with wires going onto the terminals.
The remote winch controller needs power and a ground, as well as a connection for in and out. you should be able to disconnect the wires in the back of the socket under the dash and connect there.
See diagram below. You will need to connect the ground wire on the new controller to a solid chassis ground.369436202_Screenshot_20220818-102750_SamsungNotes.jpg.104ac186f144954030fdf2d808a6ce7f.jpg
I believe the HF ones come with a plug that matches their winches so yo would have to disassemble it and figure out which wire was which to make it work. There are a dozen plus sub $20 choices on amazon that come bare wire that would be easier. No disassembly, and the wires come labeled as to function.
If you grab a set of crimp "bullet connectors" and a crimping tool you can install it and still be able to switch back to the factory setup by reconnecting the old wires for the plug in a couple minutes.
Great post. Can anyone share which color wire goes to which number connection 1 - 2 - 3 ?
with 3 prongs and 3 wires if my old math lessons from 30 years ago in high school still serve me right that’s 3 squared so 9 possible combinations to really screw up the wiring. Haha. Well, one will be right so I guess 8 to screw jt up so anyone save me the sparks flying? Thank you
They should match the "genders" in the diagram. You can test to confirm you get 12v+ on the correct one.
Connecting it to one of the others will either reel in or out, and the 3rd will do the opposite.
If you do confirm the colors feel free to post here and help the next guy out.
Register a new account
Sign in
    • By SouthernGypsy
    • By 2scoops
      I am in need of an IAC for my throttle body. I contacted JMC and they said I had to buy the whole throttle body for $209. I left a message at Joyner USA...they haven't called back. I found a Chinese company which have them for $17, but shipping is $32. With that I still have to hope it is the correct one which arrives.
      Does anyone happen to have one laying around they would sell?
      I understand a workaround would be to eliminate it and use the idle screw. I believe that would cause problems with cold start ups??? Elevation changes???
    • By Paul Angstadt
      Paul
    • By diamondjfarm
      Thanks.
    • Get More For Your Device
    • By Buck
      My father-in-law has a Hisun 750.  It has started to not change gears while running.  He can turn it off, change gears, then restart and it will change.  I thought it might have something to do with the brake but can’t find any info.  Thanks in advance for any info.
