Yes, but you would have to change the upper shock mount for the front. You could use the 8 1/2 in the back and i think the 5 1/2 in the front stock mounts. If you have somebody to weld it is notthat hard to change the upper mount on the front. it is worth it.
      Any thoughts ?
    • By allinone
    • By KimAC
      -Kim
    • By Greg Kilgore
      Got a good deal from Lowe's on an Axis 500. Same as the Hisun HS500. So I've been told.
      Anyway the wife is 5ft nothing and has trouble reaching the break and gas pedals. I'm needing a solution for making an adjustable seat for her when she drives. But has to go all the way back for me. Or my knees will be in the steering wheel.
      Anybody got a solution. Also don't like the fact that the seats are held in by the plastic.
    • By Sxs life
      Has anyone found an option to replace these junk SAIR shocks.  I have rebuilt all of them already and they are leaking again!!  Wondering if someone has found that like polaris ranger shocks fit or something like that?  I can’t find where I can search shocks by physical dimensions.
