My steering suddenly has gotten extremely hard to turn.   Any fuses, fluid etc that are logical to check first?    Thanks.   Jon
Mine is hard to steer in 4WD and it was stuck in 4WD so I took the front motor off and seen a flat gear that was binding up and I had to use a flat screwdriver to move it towards the passenger side to unlock the front diff. Now it steers normally
It is very easy to hit the switch on locking the front which is only to go straight.  If you try to turn it puts stress on the gears.  I’m considering putting a cover over switch so as not to accidentally turn on.  Front 4wheel drive no problem as long as both wheels not locked together.  The back locked together still stresses turning just not as bad as front.  Manual says locking front or back for straight only.
Register a new account
Sign in
    • By Cletus
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
    • Get More For Your Device
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
