Posted (edited)
I have a 2017 challenger with an exhaust problem. The pipe came off the exhaust port. One stud was missing and the nut from the other stud. I found the donut(gasket) It is a round flat gasket with copper in it.  I inserted it into the port inserted the pipe back in.  New stud and tightened the plate with  lock washers/ nuts.  It looks wrong. I would like to know where I can get a parts list and Schematics for this. In this forum I read that people have ordered this part for a 750 challenger on this site please tell me how to order.HPIM4629.thumb.JPG.40c71abc9486b533473f5f9c5b2fe9df.JPG
Edited by markus
Added photo
  • Alex changed the title to 2017 Cub Cadet Challenger 550 exhaust donut.
Markus I’m very new to this however go to cub cadet parts and inter the model number for your machine.  Go to gaskets and seals and then exhaust pipe gaskets. Should show item no and price. $13.33 for my 750.  Doesn’t appear to have a diagram for exhaust system.
    • By staind
      thanks Dan D. aka staind
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By Buck
