Hi everyone. New guy here. This is a project UTV. A 2015 Massimo MSU 500. Cranks over fine  BUT no spark, no fuel pump power and no injector cycle. Everything else has power and works ok.
with my fluke meter, I am getting 12v to the coil and to one of the red wires on the fuel pump plug.
The fuses in the relay box are all good. I wouldn’t think a CPS would effect the fuel pump, just the spark.  Could this be  a bad ECU?
Thanks.
Can anyone tell me if their fuel pump and injector cycle when you turn the key to the RUN position.
My thinking is that if they cycle with the key on before cranking, this rules out the crank position sensor.
  • 1 year later...
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By SpaceGhost
    • By Nikonianut
      Any options on this machine
