High Fidelity Music with the New RRP660 PLUS Intercom
By KnS
Hey Team, our issue is not as bad as some I've read here... We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select. Any suggestions? All the songs are in the root directory. Thanks, Kevin & Shelbie
By Xov
By SpaceGhost
Hello All...
