Buon giorno a tutti sono italiano e mi trovo in difficoltà con il mo rtv 900 viene importato con limitatore ( non va )
e nessuno sa dove trovarlo e come levarlo sotto sforzo o in salita quando si ha bisogno di motore muore come se mancasse gas
qualcuno sa come poter intervenire non mi interessa la velocità ma purtroppo va ad influire su la resa sotto sforzo grazie a tutti vi auguro una buona giornata
Good day everyone, I'm Italian and I'm in trouble with the mo rtv 900 is imported with a limiter (it doesn't work)
and no one knows where to find it and how to remove it under stress or uphill when you need an engine, it dies as if there was no gas
someone knows how to intervene I don't care about the speed but unfortunately it affects the yield under stress thanks to all I wish you a good day
Is the model an RTV 900 or a newer RTV X900? Also, if it has seat belts for safety, try hooking them together as some UTV's limiters only work when the seat belts are not hooked up.
I looked through the parts diagram and searched, the closest thing to a speed limiter i could find is the Diesel Engine's governor, and that's there so you won't blow up the engine.
i wonder if you may have some other issue where the engine can't get enough fuel to run under the load of going uphill+ what you may be carrying/passengers.
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By donwan
      View File 2017 Hisun Strike 900 Service Manual
      Here's the service manual for the 2017 hisun strike 900.
      Submitter donwan Submitted 05/29/2024 Category Hisun
    • By johnpeter
      2011 Polaris RZR 900 Xp On Ebay
      https://www.ebay.com/itm/266702209616?
    • By catalyst
      We own a 2020 Kubota RTV-XG-850, with only 400 hours on it and it has been at the dealer 3+ months. We were just informed our engine failed and requires a complete rebuild at only 400 hours! There is a loss of compression in cylinder #1, which is causing backfiring and a loss of power. There is also excess gas in the engine oil.
      We are just outside of the manufacture's warranty period, and they are serving us a nearly $5000 repair bill, with only a 90 day warranty.
      A member at a different forum had the same issue at 22 hours and fortunately, his RTV is under warranty. He was informed that "short tripping" (as Kubota describes it) causes gasoline to enter into the engine oil, which causes a dilution of engine oil and eventually leads to catastrophic engine failure. This killed our engine in under 400 hours!
      Is anyone else with a 2018-2022 XG-850 running into similar issues?
    • By johnpeter
      2019 Polaris RZR EPS 900 On Ebay
      https://www.ebay.com/itm/126296767212?
