TROOPER all over the Rhino
By SteveS
By D MAYNARD
Thank You,
D Maynard
Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time. Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters? Almost acts like it might be clogged if so.
By Greg Kilgore
By Ken rung
Does Anyone by chance have a owners manual and a shop manual for a 2007 800cc trooper. I just bought one and need to figure out where and how to engage and disengage the 4 wheel drive. Is it electronic or is there a hidden lever. PLEASE HELP
