Selling this for my dad, if you want/need any other pictures or information just let me know and I will get back to you asap. You can contact me here or preferably at [email protected]
2020 - MASSIMO BUCK 200X UTV, 177cc Four-Stroke, Single Cylinder
**Note** There is nothing wrong with this UTV and it has brand new all terrain tires not the original street tires. Back deck folds down completely for more cargo space.
The following information is directly from the Mossimo website:
FUEL INJECTION SYSTEM
H and L gear for better climbing
STANDARD FEATURES
EFI
Foldable Rear Bench Seat
Windshield
Hard Top
Side Mirrors
Front Bumper
2" Frame mounted hitch receiver
Dimensions
Overall Length / Width / Height Length 105 / Weight 54 / Height 73.5
Seat Height 33
Ground Clearance 11
Front / Rear Tire Front: 24x8-12 / Rear: 24x8-12
Wheelbase 63
Dry Weight 828 lbs
Towing Capacity 200 lbs
Engine
Engine Type Four-Stroke, Single Cylinder
Displacement 177 cc
Bore & Stroke 62.5 x 57.8 mm
Compression Ratio 8.8 : 1
Fuel System EFI Automatic Choke
Ignition CDI
Transmission Automatic F-N-R
Drive Train Shaft Drive; 2WD
Cooling Air
Horse Power 8.7 HP
Fuel Tank Capacity 4.8 gallons
Battery 12V 9Ah
Suspension
Front Suspension McPherson Independent Suspension
Rear Suspension Independent Double A-Arm
Brake
Front / Rear Brake Hydraulic Disc
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By bms stallion owner
    • By Nikonianut
