Do any of you out there find the Sector E1 seats  very uncomfortable? I get a sore neck after driving a short time. It seems the back is too upright.  It needs to be set back on an angle a  little. Any ideas ?
  • 4 weeks later...
Hello, I just purchased an E1 last month and the seat situation was the first thing I had to resolve.  It was giving me pain in my lower back.  Here is what I did to resolve it.  There are four brackets that hold the seat back to the frame bar.  Take out the bottom screws and loosen the top screws about half way out.  Go to the lumber yard or Lowes and buy a 2X2 8 ft. long.  Cut the 2x2 to 50".  Now slide the 2x2 between the back seat and the frame.  Put one of the flat sides against the seat so there is not a square edge creating a pressure point against the back plastic which could cause it to crack.  Adjust the 2x2 so an equal amount sticks out both sides.  Now put the lower screws back in and tighten them until they are snug, but not to where they start to bend the bracket.  Tighten the upper screws back down snug as well.  This will give you a comfortable seat back angle.  It is now about the same as my Polaris ranger which I have been happy with.  I painted my brace black so it would not look too out of place, but that is up to you.  The only down side to this fix is it pushes the bottom of the seat back forward a couple inches so you loose some of the leg clearance which was minimal to start with.  I banged my knee a couple of times on the cup holder till I got used to it.  Hope this works for you.
      Greetings All,
    • By Gorj
    • By A P
    • By rdborra
