So my trooper overheated and blew a hose last night . Took all the lines off today and checked for blockages and couldent find any .
Few days ago I refilled the coolant and I think I may have put too much in. It also seems like it wasent pumping anything to the overflow bottle as it was still full with older coolant (was a different color) . Does anyone know the psi rating for the cap so I can replace that aswell ?
You can't put in too much coolant.  Ideally, there should not be any airspace in the system - should be full as possible.  Me thinks you need to "burp" the system to get ALL the air out.  Raise the front of your Trooper as high as you can (within reason).  Start the engine and let in pump all the air into the radiator.  Refill as necessary until all the air is gone and you can't put in more coolant.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
