Have had my 750 for a whopping 90 hrs. Have put in 2 clutches 2 oil seals and now the key sheared at my rotor generator. Knocking it out of time . These machines are total garbage. I have never mistreated machine mostly drove on flat ground when it’s running. I am conctacting BBB we should get together and start a lawsuit over these hunks of junk
18 challenger had to get rid of it just junk
read my post of cchallenger 750. they are total crap. i have threatened to sue them, they do not care. told them if it breaks down again? i am taking it back to thier factory and set it on fire .biggest piece of junk i have ever bought. but i calmed down and am trading it in on a kubota diesil i should of bought the kubota instead.
    • By Gerald Mohs
    • By Joe Breaux
    • By Chile
      Chile
    • By Aaron Colona
    • By GunnersTacklebox
