Long story short , 2009 Joyner trooper 1100 , 2300kms
When you turn the key the gauges don't cycle, can't hear pump and fan doesn't turn on . Headlights work and turns over no problem . Doesn't even attempt to fire.  Fueses are good not sure about relays.
Worked fine for a little half hour run , tried to start it a couple hours later and this happened.
Where do I start checking
Check the fuses behind the drivers seat and passenger floor area. The fuse boxes are weak links and sometimes get dirt and crud in them causing bad connections at the fuse terminals.
I’ve got 7k hard miles on my 2009 T4 and it’s been fairly reliable.
Make sure you have fuel/pressure and spark!
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By D MAYNARD
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
