2004 Kawasaki Mule 3010 Diesel 4x4 KAF950B2  rack and pinion assy is held against frame by 4 socket head bolts (10mm x 23MM) holding the rack in place with metal clamps over rubber holders.  when I move my wheels the rack moves in those clamps. I have tightened the socket head bolts to the limit (they bottomed out against the frame yet the rack is still loose enough to move when the wheels are turned. It can only move the distance allowed by the clamps but I would think it shouldn't move at all.
My question is: Is this common, is it supposed to be that way?    The rubber pieces under the metal clamps ar called "Dampers" which suggests that the rack (Steering Gear) might be allowed to move for some reason???
The service manual does not mention or answer any of these questions.   Anyone know for sure??
They are indeed "dampers" intended to absorb (dampen) shock loading of the steering gear to prevent damage. The fellows that engineered it probably knew what they were doing, there is  likely a service spec somewhere defining a range of acceptable movement. The rubber can become compressed in use, allowing too much motion. If in doubt replace it, I see it's $25.71 from Kawasaki.
You can test the steering wheel free play to indirectly determine the damper's condition (after ruling out other potential causes of too much play):
from the 2004 shop manual:
    • By Jacob E freeman
    • By Clayton Walker
      After searching all summer, I finally found a company that makes a cargo rack and roof rack for the UForce XL, and I wanted to share it with fellow UForce owners. I know this is my first post, but I’m just trying to save others the time I spent researching. I bought one for hunting, and it works great, so hopefully, this helps anyone looking for a similar setup.
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By dave pasch
      Has anyone trouble shooted this transfer case? Full 12v to switch and case. No action inside case.
      Thanks Dave
