Hello All,
New to the site. I searched a little an dI am sure it has been addressed but I do not see. My current windshield is too large and does not fold up enough to open trunk. I will often have to trailer it at speeds of 75 MPH. Any suggestions on a folding windsheild tha tyou were please with that would allow for room to open trunk as well as get to the radiator.
Spencer
Got this from SxS stuff doesn't seal real good but stops the wind. I reinforced just above the hinge point with old bed frame angle iron, had more flex then I liked at 30 mph. It will allow to open the trunk
If you get this style you'll have to adjust it up till the trunk opens, then it don't seal tight to the hood. Putting foam tape on rollbars first helps to seal in winter. I'm in MI., it gets cold here.
    • By HighSon
    • By Unhappy Kioti K9 Owner
    • By Xov
