By BMurph
By BMurph
By rsar
By Cory J
Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
