I had to smash the bulb and use pliers to twist up the lamp base to get it out on the passenger side of my HS400. Thought I was going to destroy the socket--but it survived...
    • By Fordman1
      Cleaned fuel filter and am replacing mechanical fuel pump. Unbolted but can't get fuel pump out. Shaft sticks out and fuel pump hits axle and won't come out. Anyone had this problem?
    • By Randyh79
      Has anyone had to replace the dash light on their Highsun?
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By Randyh79
      Does anyone know how to adjust the headlights on a 2024 Hisun sector /Bad Boy Bandit 750? The high beams are where the low beams ought to be.
      Thanks Randy
    • By Spencer Marks
      Hello all,
      I just finished replacing my front and rear drive shafts. I drained and put new dif fluid in the rear dif. I went to the local dealer and they told me the fill capacity of the front and the transmission as I want to replcae that as well but they could not tell me how to access the fill. One how do I access the fill for front dif and 2 is the transmission fill the same as the rear dif? I don't see a dip stick or fill for the transmission but all in same area.
      Also, anyone can suggest a good shop/service manual for this bike?
      Spencer
